RE: Sig Mayhem 3D ARF
Although I've had my share of snags with GP tanks that split, I've never had it happen yet with one from Sig.
Thanks for the heads up. Will keep an eye on it.
As far as inverted flight goes, I've found that my Mahem does that eaqually well as upright. About the only difference is that you see the plane upside down.
The OS 1.20 AX is still getting run in so there are changes in throttle setting virtually every flight. A bit of a nuisance but soon that will be past. I just make certain that it is running well enough so that it does not flame out.
My firend has had his OS 90 flame out very early on every flight. On inspection, we found that the engine was shot. The crank was sloppy, side to side, the bearings were toast, the crank was badly worn and scored, the con rod big end busing was oval and on and on. We'll see what happens with his Mayhem now that he's replace the engine with a new one. We have found though that the plane lands great when deadstick.
