RCU Forums - View Single Post - Extreme Flight Extra 300-EXP 48
Old 06-21-2009 | 11:05 AM
  #37
mstam1971
Default RE: Extreme Flight Extra 300-EXP 48
It is a great plane. However, EZ connectors can only move sideways, not up and down. For that reason I would never use them for anything other than e.g. a throttle linkage and even for thet purpose I don't use them because they wear out fast.
If you wanna make decent linkages fast, your best bet is to get 4 mini swivel ball links, some 2-56 threaded rod and 4 small screws and nuts. You can use the washers from the EZ connectors. servocity.com carries the mini ball links and threaded rod.
