RCU Forums - View Single Post - hog bipe build oops
Old 06-21-2009 | 10:24 PM
dalolyn
My Feedback: (7)
Default RE: hog bipe build oops
will the hog flat spin? I did flex it hard it started out at 3/8. ten i got a 1/2" out of it I probably will cut and reslot.
Chevelle. the wing and parts are covered. and the plans stated "do not bevel the wing trailing edge." I did sand for the max deflection with the min. gap
I just goofed on one. I should of built it like all my other kits and switched to pined hinges, and fitted for none to very little gaps. I followed the instructions on this build and used the supplied CA hinges. nothing Wrong with them, but this is my first time using them.
Heres a good question for you all
why cant you ever build the plane like the plans. you always have to modify something or change it?
Wife asked me this I said cause I can
