RE: Help with electric
<span style="font-size: larger;"><span style="font-family: Comic Sans MS;">Chargers are all about the same. The look different but all come out from the same factory in Korea. Hence, you will see they all use the same number of buttons and the menu is exactly the same. I have not used the chagers from HC but you can browse and see what others who have purchased feel about it. If Ican I will use a good one. You do not cycle lipos ... they are fine on their own.
At present I am running the Tazmazo T15 AC/DC with the Flight Power external balancer, so far she has served me well.
What you will need is a watt meter. I changed the motor on my Big Stick this weekend to the 4260 but the 12x8 was still a bit too much especially when I was too lazy to cut exit holes for cooling. I burnt my ESC. Bummer ... my fault. Maybe you should try the 10x10 first and then the 11x10. That will be pulling about 50A only.</span></span>
