RCU Forums - View Single Post - Infinity engine temps
Old 06-22-2009 | 10:00 AM
bkfamily1
Default Infinity engine temps
My MXB has an Infinity 18 engine. For those of you with experience with the Infinity, does it tend to run hotter than others like the SH? If I tune to temps around 230, it is horribly rich. At those temps, it bogs like crazy, is hard to keep running and spits raw fuel out the exhaust when I pick it up and rev the engine. If I tune it until it sounds good and runs well, the temps are like 270 or 280. But like that I have to be very careful when the tank gets low or I am running on rough terrain and getting air bubbles. I have caught the temps over 300 a few times. The engine still seems to be fine and has decent pinch. I can pick up the car by the pull start. But I am worried that I am going to fry the engine or at the least dramatically shorten its life. Also, I have had to fix the pullstart a couple times, and I think the temps are causing that.
By the way, I am positive that I do not have any air leaks. I have replaced all the fuel lines, I have sealed the engine and the carb, all the fuel line connections are tight and zip-tied, the tank is sealing well and I push the lid down every single time.
I am running Wildcat Eliminator 20% and an OS A3 plug.
Bryan
