RCU Forums - View Single Post - Thrust Hp
Thread: Thrust Hp
Old 06-23-2003 | 12:59 PM
3D Joy's Avatar
3D Joy
Default Thrust Hp
APC 17 x 8 at 9300 RPMs measured 18.5 lbs thrust static.
Thrust HP : 21.67 lbs thrust static.
One could also change the air pressure, which will change the thrust a little bit. I typed 25.54 and got exactly 18.5 lbs thrust. I am just wondering if we could just change this factor to get more accurate measurements.
Another one:
APC 18 x 8 at 8400 RPMs measured 15.5 lbs thrust static.
Thrust HP : 22.22 lbs thrust static.
It is even worse here, this with the same engine plug etc.
