RCU Forums - View Single Post - EDF Mounting Incidence and Toe out?
Old 06-24-2009 | 09:02 PM
tasesq
Default RE: EDF Mounting Incidence and Toe out?
Hi All,
Thank you for your replies. Yes - i was referring to an offset in the thrust line of the engine (toe out was the wrong choice of words!)
There would not be a huge difference to the scale appearance of the model if i didn't put the 1 degree outward change to the thrust line, however if there is going to be no negligable difference between having the 1 degree, and not having the 1 degree then i would go for it.
Has anyone had any experience with 'toe out' or change of thrust line outward of a twin edf?
Thanks in advance.
