Minn's dead on, and it looks like you took the only "right" answer in here...it's completely subjective.
Like so many other things in this hobby, changing some aspect of an airplane (weight, prop, CG, a host of other things) WILL, without a doubt, change the airplane's behaviour in some (usually predictable) way. But none of them are right, wrong, better, or worse.
Bottom line...as it nearly always is...
If the plane does what you want it to do, and you enjoy flying it, then it's right.
