RE: two stick setup?
Cool, I really like driving my rig with the sticks, hope you like it as well! While everything is explained in the manual, The manual in it's own right is written poorly! I am more than happy to help!
First thing you want to do is go into the menu(pushing the roller button on the bottom right of the Radio gets you into all menus, rolling the "roller" scrolls through the options). SEE PAGE 31 in manual>
1.Go/scroll to SETUP LIST, then MODEL TYPE. You need to select the symbol that looks like an airplane. If you select the Helicopter, you will be in CCPM mode and will will not work properly. To get out of any menu, you need to de-select any option you are editing(in this first case, you wont have to do that) and scroll until you are on the upper right hand text that says LIST(Main is to get you back out of the entire menu list).
2.Scroll to the Model NAME screen and give a name to the model(you can add 10 total to this radio at any time).
3. Scroll to Power SETTINGS screen and verify the setting. Should say US not A-EU(Europe)
4. Scroll and select back to the ADJUST LIST
5. Scroll and select MIX1- Here are my settings. Set yours to suit your needs...
Mix1 Aile-> Rudd ACT
Rate L+100% R+100%
SW ELE D/R TRIM ACT
The above means that when I move my Aile stick(Aileron:right stick left and right), the Rudd(Rudder:left stick left right), will move automatically at a rate(Rate L+100% R+100%)of 100%...You can change that number(100) to anything you want. If you only want half the movement from the rear, then 50 would be the value.
There are lots of options that you can add later of course but I will get to the meat of setting 4WS and then help you later when you have the radio, if need be. I know for a fact that you will have to REVERSE one or the other of your servos to make it work correctly. Just go back to the SETUP LIST, choose reverse, and reverse the proper channel....
More later. I ran out of time...Let me know when you need more help.
Z
