RE: TT Pro 46 muffler bolt size
While I can't tell you if they are the same, I can tell you that you should go to a hardware store and test if M3 bolts will fit your muffler's threads. You don't need the right length for testing, and if they work, go ahead. But since all M3 bolts are the same (I think) you need not worry about the pitch.
