RE: Scales ?
What is the link to the scale? 11 lbs will maybe limit you to what you can weight. We weighed my plane at the field today and had to do the fuselage, wing, and landing gear, then add them up. Turns out that your 11 lb scale may not have been able to weigh it in one piece.
All that by the way side, I've been weight planes for the last three years on a 2610gm Tripple beam scale. That limits me to 5.7 lb pieces.
If you are a small plane flyer, then it should do you fine. 1 gram is about 1/30th of an ounce, so the resolution would be great. If you are flying 60 size and up, it may come up short on a full plane weight in.
Don
