RCU Forums - View Single Post - stripped blind nuts..
Old 06-26-2009 | 08:47 AM
jetmech05
Default RE: stripped blind nuts..
smaller screwdriver you gorilla....just kidding.....replacing the blind nuts is the way to go......unless you're absolutly terrified of tapping the blind out of the hole...you could try a longer screw and get through the blind nut....then secure it with a lock nut...I do that anyway to make sure I don't loosen a motor mount screw/bolt from vibration
