RE: Selecting the right prop
The best way to check for the correct prop is with a watt meter. What you want is to get the most watts at wot without exceeding the rated amps of your motor. Your motor and esc should not get beyond warm to the touch. If you cant keep your hand on either one after flight you are overloading them.
