RCU Forums - View Single Post - Tango Float Plane Conversion?
Old 06-26-2009 | 05:56 PM
JimCasey's Avatar
JimCasey
Default RE: Tango Float Plane Conversion?
Mix in a little flaperon with elevator. You can route that mix thru a switch if it flies better without it.
You won't need as much incidence that way. If you get too much incidence, it can make the plane laterally unstable on the takeoff run, pre-rotation.
Unlikely you will have any issue with the tail servos. Wing servos either.
