RCU Forums - View Single Post - need help cox motor
Old 06-27-2009 | 04:31 AM
wzak29's Avatar
wzak29
Default RE: need help cox motor
<span lang="EN">
I remember flying U-control with the .049, if you remove the fuel tank you will see a screen filter check that. Also I remember if the engine was out of fuel a squirt into the exhaust port would run the engine for about 3-4 seconds at a fairly high rpm. Also hold the prop. tightly and turn it until you feel it kick now try to start it.</p></span>
