Hi all,
My DA100 has started to act up at idle. When I chop the throttle, it will go to a low idle, then slowly speed up. It's gotten to be a real problem for IMAC. If I set the throttle trim for a slow idle, it'll deadstick at the top of a hammer. If I set the throttle trim up a few notches, it idles too fast to spin.
People say it must be too lean on the low end, but I've been richening it, and the low needle is out past where it should be. I checked the carb and reed block and they're tight. Any ideas?
Mark
