RE: Sig Hog Bipe, and and e-Flite 60
And you static tested the system for ten minutes at a time? I'm just amazed the whole set up didn't go up in smoke. I gotta be missing something here. Most folks agree a static run up should be to full throttle, and only long enough to take a meter reading. The lack of airflow on a static run(the motor and esc are sitting where airflow is at it's lowest on a prop) usually is a recipe for disaster when a system is run that long. I'm simply amazed the temps listed were real.
WOW, that's just boggles my mind.
