RCU Forums - View Single Post - 14MZ PROGRAMMING HELP NEEDED
Old 06-27-2009 | 10:50 PM
acw
Default RE: 14MZ PROGRAMMING HELP NEEDED
Dave's suggestion will work. The trick is to setup mixes such as elevators act as ailevators and ailerons act as flaps and aileron. Then you can either enable some of the mix only in some condition by changing group to single or set the mix rate to be 0%
Arnaud
