RCU Forums - View Single Post - need help cox motor
Old 06-28-2009 | 05:13 AM
wzak29's Avatar
wzak29
Default RE: need help cox motor
<span lang="EN">
I remember these so well when I was a kid, try this close the needle valve, squirt some fuel in the port and start flipping the prop. if everything is ok the engine will run for 2-4 seconds. Check that you have a copper gasket on the head also these engines are very sensitive to cold try heating the engine this will make it easier to start.</p></span>
