RCU Forums - View Single Post - PCM- Is it worth it?
Old 06-28-2009 | 01:37 PM
DC12VOLT's Avatar
DC12VOLT
Default RE: PCM- Is it worth it?
ORIGINAL: jetmech05
I have a Futaba 9 cap and my daughter has the 7 cap..I know that on the 9 cap you can change between PPM and PCM, I do it all the time. I'm pretty sure you can on the 7 cap but can't swear to it.....Are you sure you can't change between the 2 on the 6 channel? it would be in the parameters menu.....
I don't understand why you have to fly the same freq as your dad at all times.....seems to be if you're still buddy boxing that your transmitter as the master to his as the salve will work....the salve remains in the off position.....there is no license required to operate a Radio Control aircraft.....
Did I miss something?
First: I don't need to switch as I just have another radio for my standard PPM 72MHz FM receiver.
Second: I have to have my dad WITH me at all times, not FLY on the same frequency. To use the ham band, I have to be with a licensed amateur radio operator.
