RE: problem 2 or 3 blades
I'm not so sure about that.. I'd love to know though. I think I read somewhere that as you go up in blades you can go down in blade length a bit and get the same performance. I suppose if you did use the same length blade it would mean less power then because you're having the engine do more work, but lest see what others say on this.
