RCU Forums - View Single Post - Ring installation
Thread
Ring installation
06-29-2009 | 01:15 AM
23
DarZeelon
Apr 2003
8,913
Rosh-HaAyin, ISRAEL
RE: Ring installation
Quote:
ORIGINAL: captinjohn
The piston ring may have lost its tension from lean run. Put in a new ring from Frank Bowman and it will sing again!
John,
This may be true, but the ring's tension ('springing' out against the cylinder) is a very small contributor to sealing and thus to engine power.
The 'large' force that contributes to the ring seal, is high-pressure gas from compression/combustion, getting into the ring's groove and pushing the ring 'from behind', against the cylinder wall.
See the drawing. It is for a Dykes ring, but a normal ring seals similarly.
Low ring tension will, however, reduce sealing during cranking, making starting a more tedious endeavor...
Reply
Like
DarZeelon
View Public Profile
Send a private message to DarZeelon
Visit DarZeelon's homepage!
Find More Posts by DarZeelon
View iTrader Profile
