RE: Total Weights Influence
Check your CG first, then if the aircraft is nose heavy, you can carefully remove weight and check the CG each time to make sure you don't shift it to far. When satisfied, fly it. Just make sure you use the same measurement point on the wing when checking your CG.
CGr.
