RCU Forums - View Single Post - Setting up Pull Pull ??
Old 06-29-2009 | 06:56 PM
ampeater
Default RE: Setting up Pull Pull ??
Here's how I set it up in my Pup. Pic 1 shows the servos in the forward compartment to help with the cg. Second pic shows a standard crank for the rudder on the left and a home-made crank for the elevator on the right, I set in in some ball bearing blocks attached to the side of the fuse. Pic 3 shows how the wires exit. The rudder wires are crossed in the fuse, but I couldn't cross the elevator wires and try to keep it close to scale.
ID:	1227040   Click image for larger version
ID:	1227041   Click image for larger version
