RCU Forums - View Single Post - Ack! Engine running BACKWARDS!
Old 06-23-2003 | 01:46 PM
Bax
Default Ack! Engine running BACKWARDS!
Running backwards is a sign that the engine has been over-primed, as stated above. This happens with many, many, engines. Either don't prime as much, or try flipping the engine in reverse. Sometimes, though, even reverse-flipping doesn't help.
A starter may be the only solution. Just be careful not to push hard when using the starter because your engine has a bushing instead of ball bearings.
