RE: First Kit suggestions
Hi
if you know what size Warbird you want to build, buy that size engine so you will have it for the warbird. There are a lot of stable High Wing civilian type aircraft you can build as a next project that are the same size. That will help you when you go to build the warbird. You will also need the higher dollar radio and servos to go with the big plane. The Cub being one. Just depends on your taste in planes.
Vince
