RCU Forums - View Single Post - Need Hitec Eclipse Gyro Help Please
Old 06-23-2003 | 06:10 AM
mokied
Default Need Hitec Eclipse Gyro Help Please
Hi,
I was wondering if any of you might have a quick fix for the following problem?
When I flip from normal mode on my raptor to any other mode (idle up 1, ,idle up 2, or throttle hold) my tail pitches a little bit like I've got some sort of revolution mixing programmed in or something. No rev mixing or any other type of mixing is programmed in.
I am flying a telebee 701 and it doesn't matter if I'm in heading hold or piezo. It's enough to really give me quite a bit of left tail during flight.
It does diminish when I've got the gain turned way down on the gyro in either heading hold or piezo. Output to the gyro is channel 7 and input from the gyro is channel 4.
Is this a factory mix or something? Thanks for any help. I really appreciate it.
