RCU Forums - View Single Post - Escapade Problem
Old 06-30-2009 | 09:55 PM
flash over
Default RE: Escapade Problem
I have always tried using, toe OUT. Think about it. If you have toe in, when for instance the left wing gets light, the only wheel on the ground (the right side wheel) is now pushing the bottom of the plane left. This only increases the effect of the roll. If you have toe out, that wheel tends to level the plane instead. This has always solved my directional stability in taildraggers.
