RE: Mig15 :-(
Here is exactly what is happening with my Mig15 right now.
First, a little background, I had the maiden flight, it flies very well, I flew for 5 minutes and then I felt the airplane has no power so I glided it and run perfectly on the runway.
Afterwards, the motor never worked again.
The same day when I got home, I turn the Tx on, than plugged the Battery. All servos worded fine , the ESC made beep noise at the beginning and was blinking red, you can see the motor is a little bit revolves forward and backwards randomly.
Yesterday I charged the Battery to %100, this time the Tx was not bind to the Rx, I eventually figured out how to re-bind it and again all servos works fine.
But, no movement or light from the ESC or the motor.
I tried to do this process:
0 - Bind your transmitter with your plane all over again.
1 - Turn on the transmitter
2 - Put the throttle TRIM all the way down.
3 - Put the throttle all the way down.
4 - Plug in the plane to it's battery ( turn on the plane ).
5 - Move the throttle all the way up, wait LESS than one second.
6 - Move the throttle all the way down.
But nothing was happening!!!!
BTW, when I plug the battery and the Tx is off, there is a blinking red light from the esc, but no sound at all.
I need help here guys; hope someone can once and for all guide me.
I need to know if I am forgetting to do something, or the maybe the Motor/ESC is faulty.
Thank you
Dvir
