RCU Forums - View Single Post - What engine should i put in my Kadet?
Old 07-01-2009 | 02:02 PM
jetmech05
Default RE: What engine should i put in my Kadet?
the 40 LA is not a bearing engine...it uses a bushing instead.....sounds like someone threw a bucket of bolts in an engine it will do ok as your engine if you choose it to power the Kadet with it....it is the combo I learned on....you will like the 46 on the Kadet...my daughter learned with that combo when she was 9.....either will work well for you
