RCU Forums - View Single Post - Hurricane Xp engine help
Old 07-01-2009 | 02:41 PM
UrcHobby's Avatar
UrcHobby
Default RE: Hurricane Xp engine help
Low side needle needs adjustment. turn the LSN (small flat blade screw on side of carb at throttle linkage) in clockwise gently till it just hits the stop, (DO NOT TIGHTEN TOO MUCH YOU WILL DAMAGE THE NEEDLE AND SEAT!!!!!) Once you have it in turn the LSN counter clockwise out 1 full turn then 1/2 turn. That is a baseline that will get it going. while you are at it readjust you High Side Needle(where fuel line from tank hooks up to motor) same way except turn it out counter clockwise 2 full turns then 1/2 turn. Also make sure you have 1mm opening in the throttle bore(take air cleaner off and look down carb) Hope this helps ya
