RE: COVERING & PAINT!!!
I've used Nelson's paint for years with excellent results. But...when he says his paint will not work over auto primer, he is right! He said some people were having good luck with Rustoleum primer. It does not work for me. The only thing his paint will stick to is water based poly, nitrate dope, or his own primer. If you use the proper base coat, his paint is awesome!
pmw
