RCU Forums - View Single Post - CONTROL PROBLEM - WONT REVERSE
Old 07-01-2009 | 03:53 PM
Krawlin's Avatar
Krawlin
Default RE: CONTROL PROBLEM - WONT REVERSE
What kind of RC is it? Sounds like it is nitro, and the trigger on the transmitter shouldn't work the way you said. When you pull it, it should give the car throttle, when you push the trigger, it should apply brakes. If the car is nitro and it doesn't have some kind of reverse setup on the tranny, then you wont have reverse. Not to be rude, but try reading the instructions.
