RCU Forums - View Single Post - Tapered-Bore Engine Break-in - Upgraded
Old 07-02-2009 | 05:30 AM
  #253
Broken Wings's Avatar
Broken Wings
My Feedback: (20)
Default RE: Tapered-Bore Engine Break-in - Upgraded
ORIGINAL: DarZeelon
ORIGINAL: Broken Wings
Dar, you may want to contact Novarossi and let them know that their instruction manual is incorrect as well. Both the ABC as well as the Iron sleeve ring engines say to run the engine at low RPM for at least 30 minutes.............
http://www.novarossi.it/content_uk/faq/#03
Read the manual.
EDIT: Typos and link corrected...
BW,
I believe that the fact that I work for no-one has been stated repeatedly...
Although it was discussed at some point; I am not dealing for Novarossi either.
Although NR engines have the same structure and are made from identical materials as MVVS engines; NR write you must use fuel with 10% oil...
MVVS specify 20% castor oil...
Can you explain the difference? I cannot.
Their procedure seemingly hints they think their engines are ready-to-run, out of the box...
...That anything you do will not damage the engine...
The procedure detailed in this thread addresses every engine, as if it IS damage prone; if break-in is not done right.
And, BTW, NovaRossi engines and MVVS come with the same glow-plugs (made by NovaRossi).
I'm saying is that there must be alot more manuals out there that need to be corrected. Think of the engines that you could be saving.
O.S. and now NovaRossi are done, we can submit one when we find the error and you can "Redline" it for content.
