RE: Muffler vibration on OS 91 Surpass
Ksubram, <font size="4">IF</font> your engine is the newer version with the hose that I described, you can not run without muffler pressure. But if it's the earlier version without that line, you only need to do a little tweak of the needle valve and it will run fine without pressure.
