I have an old aluminum baking pot that I use when working on an engine. I clean the parts in it with alcohol and a wire brush and tooth brush then just leave everything in there and use a rag to wipe them off before they get used and lay them out on a white towel. I also have two computer chairs and both of them leak so you start out looking high over my bench and end up looking at the bench side. On this build I had every tool I owned on the bench so it was really cluttered so I had no room to lay out the parts. I saw those tappets in the pot and told myself several times not to forget them. Maybe it's an age thing?? That old mind like a steel trap line I used to use seems to be lost with the ages!!
Magnum!! Anyone have a carb for a .91 Magnum they don't want?? Too long of a story but I could really use one.
