Thanks for your reply. It doesn't really look like there is a problem with the feathering shaft, should Itake it apart and replace it anyway, or does it need to be taken apart to really know if it is bent? How do Icheck the servo gears? Do Ineed to take them apart? Same with the tail shaft. If Ican't see that it is bent from a general glance should it be ok or do Ineed to take it apart to really evaluate it? Thanks again for you quick reply earlier. I don't have anyone to fly with and my LHS seemsto be lacking in thehelicopters departmentso Iusually have to drive an hour to gosee someone knowledgeable. It's comforting to get such good info so quickly in these forums. Thanks again.
