RCU Forums - View Single Post - Need source for canopy for Curare
Old 07-03-2009 | 04:04 PM
  #68
matadco
Default RE: Need source for canopy for Curare
Finally got all the pieces together. I went ahead and painted it with Rustoleum, which is something I will never do again. I'm not very good at Monocoat but it beats the H- out of paint. I doubt if sing expensive auto paint would have been any better. Time you sand, mask, spray, remask, spray some more then mask and spray I have spent a good two plus weeks just painting. Then the engine would not fit up right so cut the nose off and rebuilt motor supports to mount sideways like I should have done in the beginning. Then more masking andn painting 3 colors, red, white and blue. Got servos in each wing and servos for each elevator. Evidently I maynot have built the rudder correctly because it is grossly tail heavy. CG may change some with new nose and motor mount. I'm at the point of connecting servo to engine, installing tank and radio. Should finish this week end. Another problem is the daily 104 temp. for the past four weeks in an non-air conditioned garage. Things go a lot slower. Keep us advised of your progress. I'll get my grand daughter to get a photo once finished.
