RE: Top Flite B-25 ARF
CCF:
That's good info. I didn't realize there is that much difference between the small and large tanks. How do you like the way yours flies, and which engines did you use?
I've decided to dump the brakes. Guess I'll just run off into the grass if need be. I'm thinking to keep the weight and the complexity down on this one, and retracts are complex enough.
