RE: ASM Su 26M Sukhoi
Jimcork1........ Thanks for the reports on the Sukhoi, I have one on order. Do you think a Supertigre 3000 is a suitable engine for this plane? Also, do I understand correctly that the control throws you used were the manual recomended lo rates were used as your hi rates, and 1/2 of the low rate was used as your low rate, ie ~1/2" throw on the ailerons and ~5/8" used on the elevator for your lo rates? As you continue to fly the plane, please keep up posted with any info that we may find useful. I do a lot of my flying with the Micropro also.
Jerry
