RCU Forums - View Single Post - line slack?
Thread: line slack?
Old 07-05-2009 | 01:31 PM
vertical grimmace's Avatar
vertical grimmace
Default RE: line slack?
I would agree that you have a warp. The best way to tell is to have someone watch you plane in level flight. Have them look to see if it is flying banked away from you or banked toward you. Most likely yours is away from you. The other area may be to check you elevater and make sure it is straight and aligned properly in relation to the wing. Also that there is no flex on one half of it. this should be a simple fix. You will just have to determine which way you need to tweak the wing.
