RE: JetJoe OWNERS thread
Very easy to take front cover off and check rpm sensor, normally if it reads zero then it is plugged in the wrong way.
I never use the gas valve and I always use external gas and turn it off myself once I see 25K during startup, I then half a one way valve (check valve) on the gas line which seals it one I remove my gas can.
Gas valve only needed if you want on board gas.
