RE: How to stall engine?
Right now it was running with the factory carb settings so your saying I should richen up the ls needle and this would help stop the engine? I think after I remove the flexshaft I'll give it a try and see if that works. I'm almost nervous to touch the settings since its running the other carb I had in place had a bad diaphram. What's the downside of having the ls needle set to rich?
