RCU Forums - View Single Post - RC TRAINER FROM SCRATCH
Old 07-05-2009 | 11:22 PM
Gray Beard
My Feedback: (-1)
Default RE: RC TRAINER FROM SCRATCH
ORIGINAL: jester_s1
The engine you're going to use isn't going to work under any circumstances.
Scratch building an airplane to try and save money will also not work under any circumstances. Even if you could build cheaper than you can buy (which you can't), you'll likely wind up with an unflyable airframe due to beginner errors.
Every beginner who wants to fly a fuel powered airplane needs to start at the same place: An ARF or RTF trainer with a .40 sized glow engine. The plane and radio and all the gear will set you back around $600 in the US once you allow for incidentals and memberships. There's no way to do it cheaper than that unless somebody gives you stuff.
I built the Sr. Telemaster as my club trainer with a used OS .60 and used Futaba standard servos with a used RX and the cheapest crap covering I could find. Total cost to get into the RC end of the hobby was under $250.00 even with the $12.00 club membership.
Three of us learned to fly with that plane before we gave it away. So much for the ARFs and RTFs. You can get into the hobby on the cheap.
