RCU Forums - View Single Post - YS FZ110 Problem
Old 07-06-2009 | 08:18 AM
petec's Avatar
petec
My Feedback: (58)
Default RE: YS FZ110 Problem
check the push rod tube o-rings and the valve cover gasket to make sure they are sealing and also check the fual line from the regulator to the carb fo a nick.
Also the LS needle is an airbleed adjustment so closing it all the way richens the idle, although whay you describe is a lean condition at idle.
As for the regulator and fuel flow at idle, the regulator is not like a gate valve, it allows a little fuel to get past at idle.
