RCU Forums - View Single Post - How to stall engine?
Old 07-06-2009 | 09:46 AM
rcguy1411
Default RE: How to stall engine?
make shure you have enough negative travel on your servo to close the carb compleetly quick way to check is disconect the servo start engine and close the carb manualy if it still keeps running then then probibly have an air leak if it stops then adjust links hope this helps
