RE: New rigger
I'm using an octura plastic 531Y prop on my little rigger. The x632 detounged is the speed prop though...you might be able to start with those (x632 being my guess).
I think if your going to use the 10L, you might want to go with something a little bigger than the 35 amp ESC. I have an ETTI Navy 70 that i'm planning on using with a Feigao 380 8L. You could go with something like that or 100-150 amp ESC...that would put you on the safe side of things!
-Kent
