RCU Forums - View Single Post - ASM Su 26M Sukhoi
Old 07-07-2009 | 11:36 AM
jimcork1
Default RE: ASM Su 26M Sukhoi
Rain can't fly []
A few notes on the sukhoi
1) I did not use servo extensions. I use solder/shrink tube and extend all leads. This way there is nothing to unplug.
2) The push rods included for the elevators were almost too long. You can't cut them they are only threaded on the end. The servo mount should have been 1/4" forward so you will have to be sure to position the control horn back far enough on the elevator. If you are too close the push rod and clevis will have to be replaced.
3) (covered this in previous post) The screws for holding the wing on were not in the box and I had to call for them. They arrived promptly and the supplier provided great support.
4) One of the clevis had a bent pin and could not be used.
5) one of the wheel collars was not properly drilled. I drilled it out to use it.
7) I added lock washers to the landing gear screws, (they were not suppose to be used) But I felt the need to insure I wasn't installing drop off gear.
8) The hole for the rudder linkage was difficult to find.
9) I used velcro to hold the tank vs. the tie wraps.
Hope this helps.
