RCU Forums - View Single Post - Autogyro with gasser 26cc
Old 07-07-2009 | 12:59 PM
NailMan
Default RE: Autogyro with gasser 26cc
I welcome all fans autogyros!
At last business has moved from a dead point and construction of mine autogyro has begun.
At present to me make details of a rotor and the rotary hinge of duralumin.
Also other colleague does plywood details of a fuselage and rotor blades on a CNC-milling cutter.
Next week I plan to assemble together a fuselage, a rotor mast which not so long ago has welded
in car-care centre.
Before manufacture of blades of a rotor, I have decided to make some sample (short pieces) blades
With a different design for a choice of the blade with the most favourable position of the CG.
Drawings I finish on a construction course so all of them time vary in trifles.
Prerotation I will use at first from electromotor GreatPlanes 42-40-800 through a belt drive.
If wind and a place on a runway will be enough for prerotation - the electric motor I will clean
that will positively affect balancing of autogyro and its total loading on a rotor.
