RCU Forums - View Single Post - FOX COMPOSITES Bae HAWK, Build thread
Old 07-08-2009 | 05:21 AM
  #683
digitech
My Feedback: (10)
Default RE: FOX COMPOSITES Bae HAWK, Build thread
ORIGINAL: Gordon W
ORIGINAL: digitech
can you guys tell me :
is it rail mounted or firewall mounted?
oleo size from pickup to axle centre from mains and front?
we do have some sets that could fit.
Hi Sandor
Pic 1 is noseleg length (120mm) from base of retract block to wheel axle on mine. Nosegear is Robart 517 105deg. Wheel dia is now 50mm.
Pic 2 shows Robart steering arm, which is separate from leg.
Pic 3 shows that piston is directly linked to swinging arm, resulting in binding at ends of travel. An intermediate link is needed.
Pic 4 shows length of mains from base of retract block to wheel axle. Retract unit is Robart 510 90deg.
Pic 5 shows inboard side of cut-off wheel yoke.
Pic 6 shows outboard side of wheel. Main wheels are now 65mm Eurokit.
Hope this helps
Gordon
Edit: I had brain fade with original Pic 1. I've now amended the length to its proper 120mm!
thanks
i am prototyping a new gear at the moment
will let you now how it goes in the next few days.
it will also fit other planes
